ros_command() and charts
I’m searching the way to plot a chart using “ros_command” function to print out wireless values as snr, ccq, etc… not in snmp pool.
Example,
Charts → data sources → +
code:
ros_command(":put [/interface wireless registration-table get number=0 signal-to-noise]")
but “last value” is always 0.
How can I print snr chart?
Thanks.
Can anybody help me please?
Very interesting question. I want to chart wireless clients:
/interface wireless registration-table print count-only
Also I want to show this count on device label.
Add Custom function:
**Name:**ros_wireless_clients_count
Description:ROS wireless clients count via ROS
Code:
ros_command("/interface wireless registration-table print count-only")
Now we can add this to the device label:
MU Connected:      [ros_wireless_clients_count()]
Add custom probe:
**Type:**Function
**Agent:**default
Available:
Error:
if (ros_wireless_clients_count()<>"", "", "")
Value:
Unit:
Clients
But sometimes Dude show that probe is down - not available, why ?
Label show correct number - 0
this works
but TCP 8291 port must be open.
Sometimes values drop to 0 until press again “ok” button. Maybe is a disk space issue…
Ciambot
What is put ?
to understand, try in new terminal
and
Also, rebooting the monitored device, dude gets the right last value instead “0”.
It is a bug of the system, I don’t know if it is in dude or in the device, but i’d like to see it fixed.
Testing on
  • Dude 4b3 in 411AH
  • Six RB711 with RoS 5.14
no such item
1
:put [/interface wireless registration-table print count-only]
1
1
