Hi
I have been trying for 2 weeks to setup a road warrior L2TP/IPSec server on my hap ac (RB962UiGS-5HacT2HnT ; v6.43.7) so I can connect my macbook Mojave (10.14.1). The Mikrotik stands behind my ISP Gateway router, which I can not discard due to a proprietary WAN authentication. Anyway, I’m pretty confident on my nating and firewalling abilities.
I’ve read every wiki out there and tried almost all setup combinations. All I can get is 4 816B UDP packets arriving at port 500 followed by the usual “The L2TP-VPN server did not respond.”
So, has anyone successfully connected a OSX Mojave to a L2TP/IPSec ROS server?
Also, how can I obtain logs from the Mikrotik? I added a rule with the topics ipsec, l2tp and ppp, but nothing shows up. The only time something shows up on the logs is when I try to connect from within the Mikrotik’s LAN. In that case the mikrotik receives 1 packet in port 500 and another in port 4500 (140B) and the log shows:
Thanks for your answer. I was already thinking this forum needed a secret cool handshake that I don’t know…
By now I’ve given up on L2TP/IPSec (also had given up on OpenVPN a few months ago!).
I managed to set up an ikev2 that’s working well with my macbook (not with my phone though…), and I erased all L2TP confs.
But again, thank you for being available to help!
I followed several guides and experimented changing many parameters. The only configuration I could show would be the very last one, if I had not erased it…
