Why there are no replays to this topic?
Maybe because changelog is as a link, not as ussualy, so here it is:
*) fixed problem - bandwidth shaping on ARES traffic was not working properly;
*) user manager - fixed security bug in user page;
*) fixed locking up in PPPoE server;
*) fixed bridging in PPTP, L2TP an PPPoE;
*) fixed bug - MPPE encryption keys received from RADIUS server were decoded
improperly on RB333;
*) added support for BGP signalled VPLS;
*) fixed bug in port remote-access - it was inserting random data, mostly
nulls, in data sent to serial port and to tcp connection.
*) fixed bug in console error propagation, code like the example below caused
console to enter busy loop:
:do { badcommandname; } while=(true);
*) fixed hotspot https walled-garden;
*) fixed bug - dhcp server failed to give out options with code > 127;
*) console - fixed numeric parameters that accept negative values, were broken
in rc12;
*) fixed port line-state values on MIPS RouterBoards;
*) fixed bug - idle-timeout & session-timeout were not disabled if they
were unset in ppp profiles;
*) fixed OSPF compatibility bug with v2.9 (and some other vendor
implementations): LS Acknowledgments were sent to wrong address;
*) fixed Broadcast flag for DHCP on RB300/RB600;
*) fix wireless nstreme packing problem;
*) improved layer7 firewall matcher memory usage;
*) console - do not add input to history if it is the same as previous line;
*) fixed bridge to forward (R)STP frames as regular if (R)STP not enabled;
*) fixed bug - configuration for missing serial ports was not tagged inactive;
*) console - fixed safe mode, it was causing wery high cpu usage and terminal
traffic;
*) console - added login parameters, passed as part of login name, after ‘+’;
can be used to disable colors (+c) and terminal autodetection (+t), e.g.
“admin+ct”;
*) dns resolver has configurable max UDP packet size;
*) fixed dns resolver - tcp queries were broken without ipv6 package;
*) added ingress priority matcher to firewall rules;
*) added number of active pcq queues to queue stats;
*) made advanced mode for wireless interface configuration in WinBox;
I really like new OSPF and PPP fixes - work great and ingress priority matcher gives addition dimension to think in.
