I was upgrading a CRS328-4C-20S-4S+ running ROS 6.44.6 to the latest table. The switch did not come back online after 5 minutes. I have another switch connected to it with LLDP, it shows the following:
IP: 192.168.88.1
Version: 2.7
Board Name: CRS328-4C-20S-4S+
I’m guessing the upgrade failed and some how loaded SwitchOS v2.7 with a default config?
Has this happened to anyone else?
Is there a way to fix this remotely? I’m able to ping it’s IP but can’t MAC telnet or SSH to it.
mkx
June 5, 2021, 7:51am
2
My guess is that you’ll need physical access to the switch. And netinstall it.
SwOS doesn’t have any MAC-something service, only way to manage it is via web interface.
do some NAT for reach 192.168.88.1 by web browser the device
upgrade swos with latest 2.13
https://download.mikrotik.com/swos2/css328/swos-css328-2.13.bin
after that select inside swos to start with RouterOS and reboot
This worked out great, thank you. I haven't worked with SWOS before and didn't know it had web management running by default.
Does anyone know if this is a known bug to look out for awhile upgrading?
