I upgraded one of our RB600 (Router 1) to the ROS v. 4 (4.4 and then 4.5). After several hours (minutes) it stops routing data to the clients (networks) which are not directly connected to it (with an exception of default route which always works). In the routing table (ip routes) it says that gateway is unreachable. With 3.30 everything works fine. My setup is following:
can you post routing information on your Router2, since there lies the problem, because as you say, when clients dirrectly behind router1 still can use resources, while users behind router2 cannot.
clients on router2 are connected either directly (gateway is on interface on router2) or through static route - this is same as on router1.
I don’t think, that the problem is on rotuer2, because:
When I looked in Winbox to the routing table on router1 all (static) routes to the other router (router2) were blue (and unreachable), but router2 itself was reachable
When I reset the router1 it started to work again for some time (several minutes/hours)
Since I downgraded router1 back to the ROS v.3.30 it has been working without problem
