ROS v. 6.3 problem
Current ROS 6.3 problem.
  1. Explore browser cannot login.
  2. Telnet window shows “Mikrotik” Name (I use ‘brand maker’ wish to remove)
  3. http://192.168.88.1/graphs/ is not showing Graph.
Did you update all packages?
Clear your broswer history and cookies.
Roy, that is the RouterOS “Identity” name, which is part of the configuration. If you want to change this, you must also upload the file “identity.auto.rsc” with the contents:
/system identity set name=“yourbrand”
Hello Nomis,
how to make “identity.auto.rsc” file?
when I start telent, it start with
Mikrotik v.6.3
Login:
This Mikrotik name is not changed.
disable Telnet :slight_smile:
