Thanks for the reply sergejs, but the problem is still there. I have try combination of security profile using WPA2/tkip, WPA2/aes-ccm, WPA/tkip, WPA2/aes-ccm with no good results.
I’ve also posted this problem (link to this thread) to OpenWRT forum, but I dont expect much on them to reply it and I’m sure the answer is “go ask to Mikrotik Support”. I hope you guys from Mikrotik would not answer the same, “go ask to OpenWRT”
(sorry this is a joke, it’s almost 6 am here and I haven’t sleep yet).
Ok, since I purchased this RB600 from a reseller in Indonesia. I’ve also asked for their support, and I hope this community would give me a hint too on how to solve this problem.
So far I have try this setup :
RB112, RB153, RB133, RB532 with ROS v2.9.51 VirtualAP :
Linksys + OpenWRT (security profile WPA or WPA2, tkip or aes-ccm) [OK]
Linksys/Asus + DD-WRT (security profile WPA or WPA2, tkip or aes-ccm) [OK]
RB600, RB153, RB112 with ROS v3.10 VirtualAP :
Linksys + OpenWRT (security profile WPA or WPA2, tkip or aes-ccm) [FAILED]
RB600, RB153, RB112 with ROS v3.10 master interface (the real AP not VirtualAP)
this is my current wireless configuration at RB600 ROS v3.10 :
add authentication-types=wpa-psk group-ciphers=tkip group-key-update=5m \
interim-update=0s mode=dynamic-keys name=broadband radius-eap-accounting=\
no radius-mac-accounting=no radius-mac-authentication=no \
radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX \
radius-mac-mode=as-username static-algo-0=none static-algo-1=none \
static-algo-2=none static-algo-3=none static-key-0="" static-key-1="" \
static-key-2="" static-key-3="" static-sta-private-algo=none \
static-sta-private-key="" static-transmit-key=key-0 supplicant-identity=\
"" tls-certificate=none tls-mode=no-certificates unicast-ciphers=tkip \
wpa-pre-shared-key=***hideme*** \
wpa2-pre-shared-key=""
^ I have also tried to change group-key-update to 1 hour.
/interface wireless
set 1 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no \
antenna-gain=0 antenna-mode=ant-a area="" arp=enabled band=2.4ghz-b/g \
basic-rates-a/g=6Mbps basic-rates-b=1Mbps burst-time=disabled comment="" \
compression=no country=indonesia default-ap-tx-limit=0 \
default-authentication=yes default-client-tx-limit=0 default-forwarding=\
yes dfs-mode=none disable-running-check=no disabled=no \
disconnect-timeout=3s frame-lifetime=0 frequency=2452 frequency-mode=\
manual-txpower hide-ssid=no hw-retries=7 mac-address=00:15:6D:XX:XX:XX \
max-station-count=100 mode=ap-bridge mtu=1500 name=wlan.DEDICATED \
noise-floor-threshold=default on-fail-retry-time=100ms \
periodic-calibration=default periodic-calibration-interval=60 \
preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=AP01-NEW \
rate-set=default scan-list=default security-profile=dedicated \
ssid=DEDICATED station-bridge-clone-mac=00:00:00:00:00:00 \
supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tx-power=15 tx-power-mode=\
card-rates update-stats-interval=disabled wds-cost-range=50-150 \
wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=\
disabled wmm-support=disabled
^ that is the master interface.
add area="" arp=enabled comment="" default-ap-tx-limit=0 \
yes disable-running-check=no disabled=no hide-ssid=no mac-address=\
02:15:6D:XX:XX:XX master-interface=wlan.DEDICATED max-station-count=200 \
mtu=1500 name=wlan.BROADBAND proprietary-extensions=post-2.9.25 \
security-profile=broadband ssid=BROADBAND \
update-stats-interval=disabled wds-cost-range=0 wds-default-bridge=none \
wds-default-cost=0 wds-ignore-ssid=no wds-mode=disabled wmm-support=\
disabled
^ that is the VirtualAP.
/interface wireless manual-tx-power-table
set wlan.DEDICATED comment="" manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,1\
1Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:\
17,54Mbps:17,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-7:\
0,HT20-8:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0,\
HT40-8:0"
/interface wireless nstreme
set wlan.DEDICATED comment="" disable-csma=no enable-nstreme=no \
enable-polling=no framer-limit=3200 framer-policy=none
TIA.
