ROS v3 RC 2 released
I was unable to find this topic, so:
What’s new in 3.0rc2:
*) added RFC 2217 server (configure under ‘/port remote-access’);
*) renamed ‘get’ tool to ‘fetch’, avoids confusion with builtin ‘get’ commands;
*) ospf - added ‘passive’ interface flag;
*) ups - fixed duplicate logging of line power state;
*) fixed bios upgrade from RouterOS on RB200;
*) added switch support for rb1xx;
*) added support for ipv6 firewall;
*) added ipv6 support to dns cache;
I tested OSPF just yesterday - finally it is possible to add client networks to the stub areas, without any risk or performance loss, just specify that client interface is “passive” - disable HELLO protocol on those interfaces. Usefully for PPPoE servers
After upgrade in first fourth firewall rulles router count thousend of millions GiB and Packets.
And there doesn’t much matter what for rules are first fourth
using rc2 on a ccoupple of wireless routers after a day of operation they start to show memory leak. Memory usage costantly increase and then the router stat to not rispond some time.
This behavior is the same since beta7.
Ros
Please make the support output file when the router is working ok. Then make the support output file when you see that the router is leaking memory, so we could see what exactly is leaking. Send those files to support@mikrotik.com
