ROS v3 RC2 bugs
some time on demo2 router is installed rc2.bug with unchangeble value in winbox is not fixed.from winbox terminal:
[demo@demo2.mt.lv] > ed, using multiline input mode
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 3.0rc2 (c) 1999-2007 http://www.mikrotik.com/
Hi
I am not sure what you mean? Could you please explain? I would like to know about bugs before attempting to test new releases.
what bug is that?
when you open in winbox new window fields are grey and you cannot change value.maybe this is because demo user have small access, but i had this bug in some beta…
is it bug? or just the usual “mikrotik” welcome screen and your resolution aor display can handle it :laughing: ?
Do you mean the screen loads as per your previous post, but you are unable to type anything?
If yes, does that screen load very slowly?
Don’t you think the problem is as simple as the latency between your network and the demo MT is just to high, which causes it to timeout?
screen loads very fast.I have 100 mbps fiber link.
you have to wait for a few seconds, it will then turn active.
In rc1 when i open any config box (in winbox) to make a change it is all greyed-out, i.e. you cannot make any changes, however when i close and reopen, only then you can make changes.
Yes, I have experienced the same symptoms. When creating a new queue for instance, you first have to close the window and open it again. I thought it had something to do with the router being wrongfully upgraded. I had a power failure while upgrading. I resolved the problem by formatting the NAND and reloading MT via Netinstall.
If you drag anything to change it arragement the add/create/new does not work.
If you click after dragging on any record, it works fine.
This happens mostly in filter/nat/mangle, etc.
That said; It’s mostly just nit-picking.
Everything works fine, especially when you recognize the quirks.
Everyone is capable of living with quirks, so long as the core functionality is working.
have problem with IPV6 in 3.0rc2
ipv6 firewall mangle print
error - contact MikroTik support and send a supout file (2)
and what is more important .. I have 6to4 interface before .. and till I upgrade to 3.0rc2 I can ping from my computer ipv6 resources in world .. now .. it’s NOT WORKING …
report bugs to support please. we will greatly appreciate any help and supout.rif files from you.
about the winbox bug - as i said, please wait a few seconds until the interface loads.
