ROS V4.7 disapears
Hello, recent was in mikrotik web site a new v4.7, and now is not present, have any bug?, I’m runing it on rb433 and x86 and does not have any problem, can you explain me if there are some problem with v 4,7 must I dowmgrade?
ARIEL
I never know about it, what i understand is V4.6 then is V5.0 Beta…
:confused: :confused: :confused:
see http://forum.mikrotik.com/t/routeros-v4-7-released/37151/1
I hope tomorrow someone from MT staff tells us when the problem could occur. And if that condition could occur on some of our routers that were upgraded - I would downgrade them right away.
I recently had a DHCP issue with v4.7 x86.
remote router: mikrotik dhcp client v4.5
mikrotik dhcp server: v4.7
A remote router obtained a DHCP from my v4.7 router. It showed up leases as “bound”. When I tried to ping the remote router, the packets were getting to the remote router, and sent back to the v4.7 router, but the torch never showed any received traffic, only sent traffic.
When I “release/renewed” the remote router’s IP, everything was fine, connection was good after that.
This sounds like it might have been the DHCP problem with v4.7.
Note! The recently released RouterOS v4.7 contained an uncommon DHCP server problem in some non standard installations, until a fix can be provided, you can use RouterOS v4.
Can tell me wich is UNCOMON DHCP SERVER I m using dhcp over x86 and have not any problem, is posible to know more clear the problem¨.
thanks in advance
ARIEL
