ROS v5.25 or higher for TILE?
I have a CCR that I want to use.
I have one rb1000 with 500 simple queues that runs 5.24.
To translate these into v6.x I have to upgrade rb1000 to v.6.x. Simple queues than stop working. I have to export, load in text program, change or remove interface target, load the rules again, see if they work. Export them and than load them in my CCR running 6.3
This while rb1000 is ‘live’ for almost 500 clients… bad idea…
So the idea wat to load 5.24 on the CCR. Export the simple queus from rb1000. Change them to my need and load them on the CCR.
The CCR is not yet in action…
But now I can’t find any v5.x for TILE!
So I hope it does exist, otherwise I am doomed…
tile don´t suport ROS 5.x
Only V6
So I found out.
I had to do it this way:
http://forum.mikrotik.com/t/how-to-migrate-simple-queues-v5-24-to-v6-x/68009/17
