[ROS v5RC1] CPU Load at 100% on SSH Logout
I ssh into my MT Box and do somthing - after /quit the CPU Load is at 100%. Only a reboot helps!
I have this problem on a RB800, RB433 and x86 all ROSv5RC1
velvet
BTW, any ETA for RC2?
just tried my RB800 on the table, login user with password, did something (/ip addr p; /ip ro p;/sy reso pri) then /quit
logging back in and everything is as usual.
log in:
[admin@x86] > /tool profile
NAME             CPU        USAGE
winbox           all        0.5%
logging          all        0.5%
management       all        0.5%
idle             all        98.5%
pppoe            all        0%
unclassified     all        0%
log out and log in again:
NAME             CPU        USAGE
ppp              all        0%
firewall         all        1.5%
logging          all        0%
management       all        53%
profiling        all        14%
bridging         all        1.5%
unclassified     all        30%
I tested again on rb433 and rb800 and this time I waited few minutes - CPU is on2 % look good! only an my alix board CPU Load is still 100%
after 3 hours rb stop working with cpu usage 100%
only reboot helps for next 3 hours
after 5 mins CPU Load OK on rb433, CPU is at 100% again.
[admin@rb433] > /tool profile
NAME             USAGE
wireless         0%
console          0.5%
dns              0%
winbox           0%
management       56.5%
profiling        0%
queuing          0%
unclassified     43%
have to find what that unclassified process is. as i see it ssh processes are identified correctly and that is something else that is using up your CPU.
the system is idle all the time until I ssh to the Box!
you can not reproduce it? login via ssh few times and /quit and you should see the 100% CPU Load.
I also have this problem but i am using Winbox … CPU Usage for “Management” goes very high (total CPU usage of the box is 100%) for a long time… only reboot really helps :frowning:
this is fixed for 5rc2, so just wait for it.
yes, rc2 works for me!
Similar problem on Ros 5.0rc5. Please fix it.
Confirmed, same problem on RB433AH with ROS 5.0rc5.
After ‘quit’ from SSH session CPU is 100% busy.
Profile tool from Winbox shows:
management - 60%
unclassified - 40%
Next SSH connection, even without login reduces CPU utilization to typical level.
Regards, Grzegorz.
wait for 5.0rc6 release.
5.0rc6 → CPU Load at 100% on SSH Logout not fixed!
