Hi
after upgrade to V6.1 the lcd of touch screen is not working properly
i am not able to slide between interface graphs
can any one figure out the issue??
Hi
I have the same problem.. Moves a bit, then the screen locks up. Everything else seems ok, but have to power-down or reboot to start the process all over again. Weird…
-tp
did you try “recalibrate”?
yes i tried it twice
after each calibrate it works for some time then back to old state
can you make a “lcd screenshot” when the screen hangs and doesn’t move?
can you also make a supout.rif file at the moment when you do this?
do i have to take an image of lcd with camera??
i did a full reset of the device and re configured and now it’s working perfectly
but normis please have a look at ticket 2013061766000953 regarding packet marking
the LCD menu has a screenshot option
[admin@mikrotik] > lcd take-screenshot
as i told above after reset it’s working fine
but i think the upload tx rate of WAN interface is showing wrong rate both on graph and in interface status
please refer to ticket 2013061866000997
admins please close the ticket above
i have found the problem
there was an ddos attack to my router
