Hi all,
since OS 6.6 i found problem in export (and then import) the configuration
Leo
Hi all,
Leo
please give more details.
if you try to export configuration file and then try to import the conf from 6.6 ros to another 6.6 ros it gives error.
If you open the file rsc you can see only 2/3 kb bytes file instead of classic 20+ kbyte (and working) 6.1 version
Until ros 6.1 (the last i tested with this funcion) all works perfectly.
Thank you.
Leo
can you check if you have this problem in 6.7 that was just released, i tested this on several routers running 6.6 and 6.7 builds and did not see the issue.
Ok now with 6.7 seems works correctly again
Ty
