ROS v7.5 MPLS - Propagate TTL
In ROS v6.x you can do this
 /mpls set propagate-ttl = no
in v7 is this supported?
In help section it was not clear how to do this but it was mentioned that it was supported in v7
https://help.mikrotik.com/docs/display/ROS/MPLS+MTU%2C+Forwarding+and+Label+Bindings
I’m not aware of any way to set this as of ROSv7.6 beta6
Maybe MikroTik can comment if the command exists
If the command does not exist today in v7 they should reflect that in the document, i just assume it was supported because that is the same reference guide you need to work with v7, this is another area needs to be improved and fixed in v7 aside from the never ending saga of ros v7 BGP implementation
