ROS V7 PPPoE ststic route
In V6 if I use PPPoE with static route gateway ping enabled all worked good, but in V7 if I have gateway check up (ping) enabled it stops working. If I uncheck to check gateway all works good.
Anyone else has the same issue?
ok after doing some labs I found it does gateway checking automatically even if you open immediate gateway on the route it shows gateway is being checked.
