Does anyone have the VendorID & Value available perhaps?
Also, looking at https://help.mikrotik.com/docs/spaces/ROS/pages/328090/Dot1X, it makes use of the Mikrotik-Switching-Filter attribute to apply rules to the switch. However, I am not seeing a “action” parameter via GUI or console to the /interface/ethernet/switch/rules command?
User Manager in ROS7 is MikroTik’s implementation of a RADIUS server, mostly to be used with devices running RouterOS as acting the RADIUS clients. That may be why it has the custom MikroTik attributes pre-defined.
