ROS4.6 winbox closing with Virtual AP
Hi Guys
Whats up with ros4.6 and winbox.
I often use a virtual AP when migrating services, or having mixed security profiles.
On 4.6 when the “virtual AP is added” all is fine, you can adjust the parameters fine like security profile and SSID etc on the new window that opens up
Then accept the settings, still fine.
Then double click the VLAN interface one more time, (suppose you want to change security profile)
Then whack the entire winbox session ends abruptly as soon as you double click the interface.
I tried it 3 times… Removed interface, starting again from scratch. Each time is the same.
Seems that once the Virtual AP interface is added, that its no longer possible to use winbox function to adjust the parameters.
I suppose a terminal session is a way around the answer, but I am not a great lover of “terminal sessions”
Is there a bug!!
Virtual AP problem is known and will be fixed in next version.
On recent rosV4.7 version the problem is the same.
ARIEL
it will be fixed in v4.8
