ROS6.0rc6 problem
Hi!
tried many 6.0RC’s so far and sent many reports to support.
Have seen good progress in ROS6, but today I had big problems.
SXT runs 100% wireless and no respons in winbox - had to downgrade to ROS5.22
RB433AH runs 100% and no respons also had to downgrade to ROS5.22, the problem
here that ethernet only ran 25kb/s and took an hour to upload ROS 5.22
ROS6.0rc6 runs fine on some boards as long as you don’t try the new function
partition. One reason could be that Mikrotik didn’t include the new firmware 3.1.1
RGDS
smal bug in latest build rc6
A bug? Where? I see the same value, just in kHz instead of MHz. :wink:
I also want to downgrade from v6.0rc6 to v5.22 ? :slight_smile:
Hi , i’ll do it too !!!
My Routerboard crash one time per day! :imp:
If you have access to the development versions try rc7. It has been better so far.
