Good day
So I started diving into RoS7 as I have received a CCR2116 that I need to install into my DC.
I have a lab set where I have 2 RoS7.4 devices.
1, CHR
2. CCR2116
CHR (Is acting as my ISP Gateway)
CCR2116 (Core router)
So I have followed tutorials and I can see that the BGP session is establishing.
And when I select Output Redistribute on the CCR I see that all the connected routs in my routing table is being sent to the CHR.
So I can confirm that the BGP session is working.
When I disable Output Redistribute and I select Output Network and I match it to the Address list in IP > Firewall it just does not seam that the
prefixes are being sent.
CCR Config
name=“bgp1”
remote.address=10.249.88.1/32 .as=65002
local.default-address=10.249.88.2 .role=ebgp
routing-table=main as=65001
output.network=BGP_Address_List
CHR Config
name=“bgp1”
remote.address=10.249.88.2/32 .as=65001
local.default-address=10.249.88.1 .role=ebgp
routing-table=main as=65002
input.filter=in-filte
So not sure if I am missing anything.
Just a note most of the tutorials I found is still referring to V7.1 so not sure if I am missing something and cant seam to find any usefull information in the Wiki/Support docs.
Any advice would be appreciated.
