ROS7.6 BGP announce bridge ipv6 subnet
I have ros 7.6b7
ebgp connection to “bird v2” on ubuntu in dual mode ipv4\ipv6 routes
with ipv4 there is no problems, ros receives and announce routes,
but with with ipv6 problem - it only receive but not announce
/ip/address/print where interface=bridge
Columns: ADDRESS, NETWORK, INTERFACE
ADDRESS NETWORK INTERFACE
;;; defconf
0 10.10.50.10/24 10.10.50.0 bridge
this ipv4 subnet is announced
and this one is not
/ipv6/address/print where interface=bridge
Flags: D - DYNAMIC; G, L - LINK-LOCAL
Columns: ADDRESS, FROM-POOL, INTERFACE, ADVERTISE
ADDRESS FROM-POOL INTERFACE ADVERTISE
0 G fd50::50/64 pool-ipv6 bridge yes
1 DL fe80::6e3b:6bff:feb7:1f78/64 bridge no
What about the rest of the setup?
You may have forgotten something, post the export for review.
what exactly to show?
here is bgp part:
/routing bgp template
add address-families=ip,ipv6 as=65150 disabled=no input.filter=in-home name=template-home
nexthop-choice=force-self output.filter-chain=notexport_wg_helpers_nets router-id=10.10.88.50 routing-table=main
/routing bgp connection
add address-families=ip,ipv6 as=65150 disabled=no hold-time=3m input.filter=in-home keepalive-time=1m20s local.role=ebgp name=
bgp-home nexthop-choice=default output.filter-chain=notexport_wg_helpers_nets .redistribute=connected remote.address=
10.10.150.10/32 .as=65001 router-id=10.10.88.50 routing-table=main templates=template-home
/routing filter rule
add chain=in-home disabled=no rule=“if (dst == 0.0.0.0/0) {\r
\n reject\r
\n} else {\r
\n accept\r
\n}”
add chain=notexport_wg_helpers_nets disabled=no rule=“if (dst == 0.0.0.0/0 or dst == 10.10.88.48/30 or dst == 10.10.150.8/30 or
\r
\n (bgp-input-remote-addr != 10.10.88.49 and bgp-input-remote-addr != 10.10.150.50) or\r
\n dst == ::/0) {\r
\n reject\r
\n} else {\r
\n accept\r
\n}”
any ideas?
