mmc
December 13, 2021, 3:09pm
1
hi,
via winbox i found no way how to move any rule.
via cli it shall work with the ‘move’ command, but the move command doesn’t do anything within the same chain:
[admin@m] /routing/filter/rule> print
Flags: X - disabled, I - inactive
0 ;;; source-adress for all generated traffic
chain=ospf_in rule="set pref-src 192.168.1.1;"
1 chain=ospf_out rule="if (dst in 192.168.0.0/16) {\r\n accept;\r\n}"
2 chain=ospf_out rule="if (protocol connected) {\r\n accept;\r\n}"
3 chain=ospf_out rule="reject;"
4 chain=ospf_in rule="reject;"
5 chain=ospf_in rule="accept;"
[admin@m] /routing/filter/rule> move 1 2
disable and enable works well, but that’s it.
this makes the whole new routing filters absolutely unusable for my point of view, when you have real life setups with tons of complex filtering.
somebody any idea how this could work?
aleksis
December 13, 2021, 5:28pm
2
move command argument ‘destination’ works like “place-before” so to move rule 1 one place further you have to do ‘move 1 3’.
mmc
December 15, 2021, 3:37am
3
@aleksis : yes you are right, thanks, that works with cli move command now:
0 chain=one rule="accept;"
1 chain=one rule="reject;"
2 chain=two rule="accept;"
3 chain=two rule="reject;"
[admin@m] /routing/filter/rule> move 0 2
0 chain=one rule="reject;"
1 chain=one rule="accept;"
[admin@m] /routing/filter/rule> move 0 3
1 chain=two rule="accept;"
2 chain=one rule="reject;"
[admin@m] /routing/filter/rule> move 2 1
but for my point of view it’s still unusable. when you have a lot routing filters in separate chains (in a typical bgp peer setup you easily have 100+ rules), the cli only handling is too limited to deal with big tables.
move needs a winbox implementation and also a proper sorted view respecting the flow order of the rules.
