In ROS6, one could set bgp-communities in /ip route. How does one do this in ROS7? My config gets clobbered when upgrading in the lab and makes me quite fearful to do it in production.
BGP attributes must be set in the routing filters. Setting BGP attributes for non-BGP routes did not make much sense. It was only good for testing, aka an easy and fast method to generate fake BGP routes.
I would agree that setting bgp attributes for non-bgp route doesn’t make sense, but if a filter is using the community to decide whether or not to advertise a route, then being able to set the community in the local routing table makes perfect sense.
In ROS6, if I want to create a local route and have it advertised to the rest of my network, peers, or transit providers, all we need to do is create the blackhole route for the prefix and set the community.
In ROS7, we not only have to create the blackhole route, but now we also have to create a filter to assign a community to it, effectively doubling the work (and chances to make a mistake).
IMO, MT should bring back the ability to set some BGP attributes while creating anchor routes.
Our company also add BGP communities for static routes. it is used for easy and fast updating of BGP communities and propagate BGP announcement to Juniper Routers and then to our upstream transit provider. like blackholing an IP that is under DDOS, sending under attack prefix to clean pipe service.
We are managing like 500 announcements. Each announcement has lots of communities. Each communities represent an announcement to a particular upstream/peer.
each announcements must be able to update BGP communities without interfering other. If routerOS v7 requires to set BGP communities in filter only, then it will be like hundreds of filter rules. It will just be unmanagable and too complicated for some of our technician. So, please consider to add the features back.
