The new documentation applies to ROS7, not the earlier versions. Not exclusively, obviously, but as someone new to your product figuring out when the new documentation is applicable and when it isn’t is rather a pain. Any idea when ROS7 will have a stable release so that I can start using it and then reliably use the new documentation?
Are you looking for the right answer… then you should use my opinion LOL
When the first LONG TERM 7.X version is released is when I will switch from my tile device to version 7,
Seriously though, it depends on your uses for the Router.
If there are still unresolved known issues in an area of functionality that you need, then dont switch.
Yeah, it’s something I want reasonable dependability on, so I suspect I’ll be stuck with 6 until they have something reliable.
Incidentally, you don’t happen to know why the static routing option in Mangle (action= route) performs so poorly do you? Or why it is so poorly documented? Or if those facts are connected?
