ROSE Storage NFS Client Mount Help
# 2023-08-21 15:18:47 by RouterOS 7.11
# model = C53UiG+5HPaxD2HPaxD
/disk
set cf16ga slot=cf16ga type=hardware
add nfs-address=192.168.41.22 nfs-share=pmnt/0256g0/esxi slot=nfs-serial type=nfs
Looks like ROSE Storage NFS client is working:
[cpino@c53uig] /disk> print
Flags: B - BLOCK-DEVICE; M - MOUNTED
Columns: SLOT, MODEL, SERIAL, INTERFACE, SIZE, FREE, FS, RAID-MASTER
#    SLOT        MODEL                                 SERIAL                INTERFACE                    SIZE            FREE  FS    RAID-MASTER
0 BM cf16ga      SanDisk Ultra Fit                     4C530123310727109425  USB 3.00 5000Mbps  16 008 609 792  15 648 243 712  ext4  none
1    nfs-serial  nfs://192.168.41.22/pmnt/0256g0/esxi                        network                                                  none
The NFS volume enumerates and System Log is clean (info level notices) however there is no MOUNTED flag and
/file print
shows only:
Columns: NAME, TYPE, CREATION-TIME
#  NAME               TYPE       CREATION-TIME
0  cf16ga             disk       2023-08-21 14:28:53
1  cf16ga/lost+found  directory  2023-08-21 14:28:53
How does one get the NFS volume mounted?
