All the good days!
My Internet provider Rostelecom, connect the router (Iskratel E39) to provide interactive television services. Their router is working. His L2 settings (vlans and bridges), attached to the topic. 423 Vlan for pppoe client connections. I can not configure my mikrotik routerboard 750gl.
I’ve tried /interface vlan add interface=ether5-gateway name=vlan_pppoe vlan-id=423 But pppoe clinet does not connect and the utility to scan the pppoe does not show the MAC address.
Also i try /interface ethernet switch set ether1-gateway vlan-mode=secure vlan-header=leave-as-is vlan-id=423
And it does not work too.
I think may be i need to setup PVID setting, but i dont found it.
Help me please!
Iskratel E39 config
my 750gl config
# jan/02/1970 00:12:29 by RouterOS 6.32.3
# software id = 95JZ-QS87
set [ find default-name=ether1 ] master-port=ether2-master-local name=\
ether1-slave-local
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=\
ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=\
ether4-slave-local
set [ find default-name=ether5 ] mac-address=xxxxxxxxxxxxxxx master-port=\
ether2-master-local name=ether5-gateway
/interface vlan
add interface=ether5-gateway l2mtu=1594 name=vlan5_423 vlan-id=423
/interface pppoe-client
add add-default-route=yes interface=vlan5_423 max-mru=1480 max-mtu=1480 mrru=\
1600 name=pppoe-out1 password=xxxxxxxxxxxxxxx use-peer-dns=yes user=\
777xxxxxxxxxxx
/ip neighbor discovery
set ether1-slave-local discover=no
add address=192.168.1.2/24 interface=ether2-master-local network=192.168.1.0
set allow-remote-requests=yes
