Hi, I’m having trouble selecting the active default route learned by iBGP. If I understand the following document correctly (https://wiki.mikrotik.com/wiki/Manual:BGP_Best_Path_Selection_Algorithm), the chosen route will be determined in the first instance by the weight assigned to that prefix. However, I’m not being able to select the preferred route using this parameter:
/ip route print detail where routing-mark=INET
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
0 ADb dst-address=0.0.0.0/0 gateway=192.168.1.1 gateway-status=192.168.1.1 recursive via 192.168.100.100 ether1 distance=200 scope=20 target-scope=10
routing-mark=INET bgp-weight=0 bgp-local-pref=100 bgp-med=0 bgp-origin=incomplete bgp-ext-communities="RT:65000:10,RT:65000:110"
1 Db dst-address=0.0.0.0/0 gateway=192.168.1.1 gateway-status=192.168.1.1 recursive via 192.168.100.100 ether1 distance=200 scope=20 target-scope=10
routing-mark=INET bgp-as-path="65010,65011" bgp-weight=1 bgp-local-pref=100 bgp-med=0 bgp-origin=igp bgp-ext-communities="RT:65000:20,RT:65000:120"
It can be seen that the active route has a lower weight than the other route present. Is there an error in my interpretation of the route selection process?
