Hi!
I using MPLS over PPP (PPPoE,L2TP,SSTP) in ROSv6, and tried it on ROSv7 without success.
LDP neigborship build up, but forwarding doesn’t working. MPLS forwarding table is empty and label mappings are inactive:
[oreggin@rtr1.vtkl20] > mpls/export
# dec/28/2021 22:49:22 by RouterOS 7.1.1
# software id = XXXX-XXXX
# model = RB4011iGS+
# serial number = XXX
/mpls interface
add interface=L2TP mpls-mtu=2560
/mpls ldp
add disabled=no lsr-id=10.1.1.20 vrf=main
/mpls ldp interface
add accept-dynamic-neighbors=yes disabled=no interface=L2TP transport-addresses=10.1.1.20
[oreggin@rtr1.vtkl20] > mpls/ldp/neighbor/print
Flags: D, I - INACTIVE; O, T - THROTTLED
Columns: TRANSPORT, LOCAL-TRANSPORT, PEER, ADDRESSES
# TRANSPORT LOCAL-TRANSPORT PEER ADDRESSES
0 DO 10.1.1.1 10.1.1.20 10.1.1.1:0 10.1.1.1
192.168.4.254
1.2.3.4
5.6.7.8
[oreggin@rtr1.vtkl20] > mpls/forwarding-table/print
[oreggin@rtr1.vtkl20] > mpls/ldp/local-mapping/print
Flags: I - INACTIVE; D - DYNAMIC; E - EGRESS; G - GATEWAY; L - LOCAL
Columns: VRF, DST-ADDRESS, LABEL, PEERS
# VRF DST-ADDRESS LABEL PEERS
0 ID G main 0.0.0.0/0 impl-null 10.1.1.1:0
1 IDE L main 10.1.1.0/24 impl-null 10.1.1.1:0
2 IDE L main 10.1.1.1 impl-null 10.1.1.1:0
3 IDE L main 10.7.0.0/16 impl-null 10.1.1.1:0
4 IDE L main 10.40.0.0/16 impl-null 10.1.1.1:0
5 IDE L main 10.203.1.8 impl-null 10.1.1.1:0
6 IDE L main 192.168.1.0/24 impl-null 10.1.1.1:0
7 IDE L main 192.168.5.0/24 impl-null 10.1.1.1:0
8 IDE L main 192.168.66.1 impl-null 10.1.1.1:0
9 IDE L main 5.6.7.8 impl-null 10.1.1.1:0
10 IDE L main 192.168.4.0/24 impl-null 10.1.1.1:0
11 IDE L main 10.1.1.10 impl-null 10.1.1.1:0
12 IDE L main 192.168.7.0/24 impl-null 10.1.1.1:0
[oreggin@rtr1.vtkl20] > mpls/ldp/remote-mapping/print
0 ID main 10.1.1.10 impl-null 10.1.1.1:0
1 ID main 10.1.1.20 impl-null 10.1.1.1:0
2 ID main 10.1.1.69 impl-null 10.1.1.1:0
3 ID main 0.0.0.0/0 impl-null 10.1.1.1:0
4 ID main 192.168.4.0/24 impl-null 10.1.1.1:0
5 ID main 5.6.7.0/24 impl-null 10.1.1.1:0
6 ID main 172.16.8.0/22 impl-null 10.1.1.1:0
7 ID main 1.2.3.0/25 impl-null 10.1.1.1:0
8 ID main 192.168.7.0/24 impl-null 10.1.1.1:0
9 ID main 192.168.6.0/24 impl-null 10.1.1.1:0
10 ID main 192.168.5.0/24 impl-null 10.1.1.1:0
Is it known this is not works? If so will it be planned to get it working in later version?
Thanks,
oreggin
