I´m having freezing incidence when connected the RouterBoard 44 to a AMD PC motherboard environment. but when is conencted to a motherboard Pentium environment the PC works fine.
I short words the RouterBoard 44 makes not the AMD PC to boot up, and even a Ctrl+Alt-Del doesn’t work, but if take off the PC is booting with no problem.
any one has the same problem out there.
