HI, i have two network 200.200.200.0/24 and 200.200.231.0/24
i have a server ip is 200.200.200.150, and want user from 200.200.231.0/24 see the server.
please help
please help
I’m not sure what you mean by “see the server”, but you probably can’t ping the server from the host in the other subnet (ip range).
The reason for this is because the PC trying to access the server sees that the IP you’re trying to access is not in any of it’s own subnets and passes it on to it’s default gateway (probably being your broadband router).
The server 200.200.200.150 also won’t be able to ping the client PC’s IP for the same reason.
Give us more info about your setup including internet connections/routers, etc. if you can’t manage to fix it.
