route /28 netmask
Hello? i got /28 from my isp, but i cant understand how to use it.
the ips are route to 10.xxx.10.202/30, and 10.xxx.10.201/30 is my gateway as isp.
and my ips xx.xx.32.208/28
What now?
anybody? that now the answere?
How is your question related to Mikrotik ROS? This is a Mikrotik ROS forum not a TCP/IP class.
Then 99% of this forum is not about ROS it self.
If you look at the forum you will get that everyboody ask about BGP, OSFP, MPLS, MME, RIP, HWMPplus, DHCP, Wirless: about cables and anntena etc!!! All this is things that you can do whit ROS.
place the /28 subnet on your internal interface. place the /30 subnet on your external interface. add a default route to their side of the /30 subnet. you shouldn’t need nat in this setup unless you know you want it.
Hey, thx for answare but im littel un secure.
When you say place the /28 on my internal interface? eks xx.xx.xx.208/28 on the ether2 as ipaddrese or on the route?
Will post my config.
10.xxx.3.202/30 this is the link addresse
10.xxx.3.201/30 is the provider addresse
62.xx.32.208/28 is my ipnet
192.168.100.0/24 is my local ips to all the mikrotik divice.
[admin@GG_GW] > ip address print
ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.100.1/24 192.168.100.0 192.168.100.255 ether2
1 10.xxx.3.202/30 10.xxx.3.200 10.xxx.3.203 ether1
2 62.xx.32.208/28 62.xx.32.208 62.xx.32.223 ether2
DST-ADDRESS PREF-SRC GATEWAY-STATE GATEWAY DISTANCE INTERFACE
0 A S 0.0.0.0/0 reachable 10.xxx.3.201 1 ether1
1 ADC 10.xxx.3.200/30 10.xxx.3.202 0 ether1
2 ADC 62.xx.32.208/28 62.xx.32.208 0 ether2
3 ADC 192.168.100.0/24 192.168.100.1 0 ether2
is this rigth?
yes, something like this. but… what do you want to achieve?
What i want is to route this addrese to my network. so my clients can get public ips.
but i cant get it to work?
Maybe your ISP forgot to route this network to your MikroTik. It’s easy to check this if you give us an address.
how exactly do you want to give IPs to your clients?
Did get it to work, wrong on cable bettwen isp and me. strange it was new cable.
