Hi
I´ve reading a lot of threads here at the forum about the /29 IPs delivered from the ISP, but I am still confuce and not having my config properly done.
The ISP delivered the /29 Public IP´s by a /31 Upstream link (this ls the internal ISP Link)
What I am trying to do is:
1 - ISP UPstream xxx.xxx.xxx.18/31 to MT1 xxx.xxx.xxx.19/31 (In order to stablish the ISP Upstream link. this currently works)
2 -Then, having other MT2 Router connected to WAN 2 with xxx.xxx.xxx.51/29 as Public IP (is in here where I am missing something as Theres no Internet access in here)
been MT1 the GW for MT2
/ interface bridge
add name=WanBridge
set [ find default-name=ether1 ] name=Wan1
set [ find default-name=ether2 ] name=Wan2
set [ find default-name=ether3 ] name=Wan3
set [ find default-name=ether3 ] name=Wan4
add bridge=WanBridge ingress-filtering=no interface=Wan1
add bridge=WanBridge ingress-filtering=no interface=Wan2
add bridge=WanBridge ingress-filtering=no interface=Wan3
add bridge=WanBridge ingress-filtering=no interface=Wan4 \
add address=xxx.xxx.xxx.19/31 interface=WanBridge network=xxx.xxx.xxx.18
add address=xxx.xxx.xxx.56/29 interface=WanBridge network=xxx.xxx.xxx.50
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=xxx.xxx.xxx.18
routing-table=main scope=30 suppress-hw-offload=no target-scope=10
