route all traffic from a VM to another which runs a VPN
Hi Folks!
I’m having 2 VM on virtualbox. I have a vpn client which is not available on linux, want to work on linux but am screwed with the vpn client which is only supported on windows.
On my current resolution which is really not ideal, I’m having /etc/host redirections for some of the hosts and ssh tunnels vm1->vm2 to make some services work.
Have 2 vms:
  • vm1 linux
    vm2 windows with a vpn client
Is there a way into my mikrotik to route all trafic from a given IP to the other IP through its VPN?
Many Thx!
The Windows VM running the VPN client must provide “internet connection sharing” in order that you could use it as an entry point to the VPN tunnel for some other device, and you don’t need a Mikrotik to facilitate such connection to the Linux VM - you simply create a virtual network with one NIC of the Windows VM and one NIC of the Linux VM, attach a DHCP client to that NIC on the Linux VM, tell the Windows to share the “internet connection” from the VPN client interface to that NIC, and let the Linux use 192.168.137.1 as the gateway for whatever traffic you need to send via the VPN (Windows use 192.168.137.0/24 as the “LAN interface” in this arrangement).
The only thing I’m not sure about is whether Virtualbox supports virtual networks where the host system doesn’t participate.
Did read many times, but am not able to set what you are saying. Could you be more specific and point me out some documentation for that please? Thx!
I don’t understand what you don’t understand :slight_smile:
Here’s a link on “internet connection sharing” on Windows.
Use the VPN interface as the “internet” uplink to be shared. The Windows VM becomes a router with NAT, acting as a DHCP server on its LAN side.
On the virtualbox, you need to configure a virtual switch to connect the “LAN” interface of the Windows VM with the “WAN” interface of the Linux VM.
