Hello! I’ve been trying out RouterOS v7 a bit, and don’t know how to port my simple configuration for routing traffic to VPN for all IPs blocked by my provider.
In v6 I did the following (assuming pptp-out1 exists and is running) - this routes all traffic for received BGP prefixes through a VPN (and BGP requests themselves are sent out via a VPN too).
I understood that I can do roughly the same (without update-source) for instance and peer, but I’m not sure about filter since there’s no
set-in-nexthop-direct
anymore.
/routing bgp template set antifilter as=64999 hold-time=4m input.filter=bgp_in keepalive-time=1m multihop=yes name=antifilter
# How do I specify that I want this connection to be done through pptp-out1 ?
/routing bgp connection add local.role=ibgp remote.address=51.75.66.20/32 template=antifilter
# How do I specify that I want traffic matching this rule to go through pptp-out1 ?
/routing filter rule add action=accept chain=bgp_in
/ip firewall nat add chain=srcnat action=masquerade out-interface=pptp-out1
But v7 completely changed the way BGP configuration works, so I’m at a loss for how I can replicate this in v7.
Any help would be appreciated!
(where 192.168.1.2 is the remote address of the VPN) it now works.
There’s a problem with that though - if the remote address of the VPN changes I’ll have to edit that. “gw>pptp-out1” didn’t work, so I’m still not sure if the way I made it work is the best
I have created Hub and Spoke setup using SSTP mikrotik version is 7.10.1. At HUB, in remote address i have created a pool of 10.10.10.0/24 so that spokes obtain tunnel ip from this series (HUB sstp tunnel IP is fixed). At spoke, i have two broadband and used Reverse lookup concept for Failover. over the tunnel, i am using eBGP and advertising a public IP of /30. So when one of the Broadband goes down on Spoke, than assigned tunnel ip gets changed.
So HUB learn the public ip from Spoke tunnel IP address (Db) but in order to work it, i have to create a static route shown in above imge. but during failover tunnel ip of spoke chages and i have to manually cheche the “As” route to changed Tunnel IP address of Spoke at HUB.
Please help to understand this behavior. Ideally Manual Static route need not configure.
