I'm wondering when it will be fixed, I'm installing every new version od RouterOS for x86 and stil is the same -> route cache overflow.
I've contacted the support about it, Maris reply me that "It could be related to gre over ipsec or 6to4 tunnels." and nothing, few supout was send by me - no answer.
Ticket is: [Ticket#2014101766000756]
It look's like below, only ONE known workaround is reboot by script who someone write on this forum. Issue is valid from years.
script:
:local act [/ip route cache get cache-size]
:local max [/ip route cache get max-cache-size]
print some debug info
:log info ("Actual route cache size: $act")
:log info ("Max. route cache size: $max")
:log info ("If active route cache size: $act>=60000 reboot required")
if (($max-$act)<=2048) do={
/system reboot
Running every 5min, check and if needed reboot, now reboot is about every 20h or less.
I don't know what to do, I have valid license and no one is going to fix that. I can even buy new license if this issue will be fixed.
Dec 16 17:42:03 router script,info Max. route cache size: 65536
Dec 16 17:42:03 router script,info If active route cache size: 3153>=60000 reboot required
Dec 16 17:47:03 router script,info Actual route cache size: 3885
Dec 16 17:47:03 router script,info Max. route cache size: 65536
Dec 16 17:47:03 router script,info If active route cache size: 3885>=60000 reboot required
Dec 16 17:52:03 router script,info Actual route cache size: 4014
Dec 16 17:52:03 router script,info Max. route cache size: 65536
Dec 16 17:52:03 router script,info If active route cache size: 4014>=60000 reboot required
Dec 16 17:57:03 router script,info Actual route cache size: 4123
Dec 16 17:57:03 router script,info Max. route cache size: 65536
Dec 16 17:57:03 router script,info If active route cache size: 4123>=60000 reboot required
Dec 16 18:02:03 router script,info Actual route cache size: 4336
Dec 16 18:02:03 router script,info Max. route cache size: 65536
Dec 16 18:02:03 router script,info If active route cache size: 4336>=60000 reboot required
Dec 16 18:07:03 router script,info Actual route cache size: 5387
Dec 16 18:07:03 router script,info Max. route cache size: 65536
Dec 16 18:07:03 router script,info If active route cache size: 5387>=60000 reboot required
Dec 16 18:12:03 router script,info Actual route cache size: 5291
Dec 16 18:12:03 router script,info Max. route cache size: 65536
Dec 16 18:12:03 router script,info If active route cache size: 5291>=60000 reboot required
Dec 16 18:17:03 router script,info Actual route cache size: 6171
Dec 16 18:17:03 router script,info Max. route cache size: 65536
Dec 16 18:17:03 router script,info If active route cache size: 6171>=60000 reboot required
Dec 16 18:22:03 router script,info Actual route cache size: 6619
Dec 16 18:22:03 router script,info Max. route cache size: 65536
Dec 16 18:22:03 router script,info If active route cache size: 6619>=60000 reboot required
Dec 16 18:27:03 router script,info Actual route cache size: 6720
Dec 16 18:27:03 router script,info Max. route cache size: 65536
Dec 16 18:27:03 router script,info If active route cache size: 6720>=60000 reboot required
Dec 16 18:32:03 router script,info Actual route cache size: 7074
Dec 16 18:32:03 router script,info Max. route cache size: 65536
Dec 16 18:32:03 router script,info If active route cache size: 7074>=60000 reboot required
Dec 16 18:37:03 router script,info Actual route cache size: 6128
Dec 16 18:37:03 router script,info Max. route cache size: 65536
Dec 16 18:37:03 router script,info If active route cache size: 6128>=60000 reboot required
Dec 16 18:42:03 router script,info Actual route cache size: 6138
Dec 16 18:42:03 router script,info Max. route cache size: 65536
Dec 16 18:42:03 router script,info If active route cache size: 6138>=60000 reboot required
Dec 16 18:47:03 router script,info Actual route cache size: 5671
Dec 16 18:47:03 router script,info Max. route cache size: 65536
Dec 16 18:47:03 router script,info If active route cache size: 5671>=60000 reboot required
Dec 16 18:52:03 router script,info Actual route cache size: 5742
Dec 16 18:52:03 router script,info Max. route cache size: 65536
Dec 16 18:52:03 router script,info If active route cache size: 5742>=60000 reboot required
Dec 16 18:57:03 router script,info Actual route cache size: 6571
Dec 16 18:57:03 router script,info Max. route cache size: 65536
Dec 16 18:57:03 router script,info If active route cache size: 6571>=60000 reboot required
Dec 16 19:02:03 router script,info Actual route cache size: 6887
Dec 16 19:02:03 router script,info Max. route cache size: 65536
Dec 16 19:02:03 router script,info If active route cache size: 6887>=60000 reboot required
Dec 16 19:07:03 router script,info Actual route cache size: 7982
Dec 16 19:07:03 router script,info Max. route cache size: 65536
Dec 16 19:07:03 router script,info If active route cache size: 7982>=60000 reboot required
Dec 16 19:12:03 router script,info Actual route cache size: 6867
Dec 16 19:12:03 router script,info Max. route cache size: 65536
Dec 16 19:12:03 router script,info If active route cache size: 6867>=60000 reboot required
Dec 16 19:17:03 router script,info Actual route cache size: 7551
Dec 16 19:17:03 router script,info Max. route cache size: 65536
Dec 16 19:17:03 router script,info If active route cache size: 7551>=60000 reboot required
Dec 16 19:22:03 router script,info Actual route cache size: 7672
Dec 16 19:22:03 router script,info Max. route cache size: 65536
Dec 16 19:22:03 router script,info If active route cache size: 7672>=60000 reboot required
Dec 16 19:27:03 router script,info Actual route cache size: 6774
Dec 16 19:27:03 router script,info Max. route cache size: 65536
Dec 16 19:27:03 router script,info If active route cache size: 6774>=60000 reboot required
Dec 16 19:32:03 router script,info Actual route cache size: 7218
Dec 16 19:32:03 router script,info Max. route cache size: 65536
Dec 16 19:32:03 router script,info If active route cache size: 7218>=60000 reboot required
Dec 16 19:37:03 router script,info Actual route cache size: 8129
Dec 16 19:37:03 router script,info Max. route cache size: 65536
Dec 16 19:37:03 router script,info If active route cache size: 8129>=60000 reboot required
Dec 16 19:42:03 router script,info Actual route cache size: 7328
Dec 16 19:42:03 router script,info Max. route cache size: 65536
Dec 16 19:42:03 router script,info If active route cache size: 7328>=60000 reboot required
Dec 16 19:47:03 router script,info Actual route cache size: 7901
Dec 16 19:47:03 router script,info Max. route cache size: 65536
Dec 16 19:47:03 router script,info If active route cache size: 7901>=60000 reboot required
Dec 16 19:52:03 router script,info Actual route cache size: 8503
Dec 16 19:52:03 router script,info Max. route cache size: 65536
Dec 16 19:52:03 router script,info If active route cache size: 8503>=60000 reboot required
Dec 16 19:57:03 router script,info Actual route cache size: 8472
Dec 16 19:57:03 router script,info Max. route cache size: 65536
Dec 16 19:57:03 router script,info If active route cache size: 8472>=60000 reboot required
Dec 16 20:02:03 router script,info Actual route cache size: 8340
Dec 16 20:02:03 router script,info Max. route cache size: 65536
Dec 16 20:02:03 router script,info If active route cache size: 8340>=60000 reboot required
Dec 16 20:07:03 router script,info Actual route cache size: 8528
Dec 16 20:07:03 router script,info Max. route cache size: 65536
Dec 16 20:07:03 router script,info If active route cache size: 8528>=60000 reboot required
Dec 16 20:12:03 router script,info Actual route cache size: 8218
Dec 16 20:12:03 router script,info Max. route cache size: 65536
Dec 16 20:12:03 router script,info If active route cache size: 8218>=60000 reboot required
Dec 16 20:17:03 router script,info Actual route cache size: 9262
Dec 16 20:17:03 router script,info Max. route cache size: 65536
Dec 16 20:17:03 router script,info If active route cache size: 9262>=60000 reboot required
Dec 16 20:22:03 router script,info Actual route cache size: 9951
Dec 16 20:22:03 router script,info Max. route cache size: 65536
Dec 16 20:22:03 router script,info If active route cache size: 9951>=60000 reboot required
Dec 16 20:27:03 router script,info Actual route cache size: 10311
Dec 16 20:27:03 router script,info Max. route cache size: 65536
Dec 16 20:27:03 router script,info If active route cache size: 10311>=60000 reboot required
Dec 16 20:32:03 router script,info Actual route cache size: 11012
Dec 16 20:32:03 router script,info Max. route cache size: 65536
Dec 16 20:32:03 router script,info If active route cache size: 11012>=60000 reboot required
Dec 16 20:37:03 router script,info Actual route cache size: 10288
Dec 16 20:37:03 router script,info Max. route cache size: 65536
Dec 16 20:37:03 router script,info If active route cache size: 10288>=60000 reboot required
Dec 16 20:42:03 router script,info Actual route cache size: 10718
Dec 16 20:42:03 router script,info Max. route cache size: 65536
Dec 16 20:42:03 router script,info If active route cache size: 10718>=60000 reboot required
Dec 16 20:47:03 router script,info Actual route cache size: 11258
Dec 16 20:47:03 router script,info Max. route cache size: 65536
Dec 16 20:47:03 router script,info If active route cache size: 11258>=60000 reboot required
Dec 16 20:52:03 router script,info Actual route cache size: 11731
Dec 16 20:52:03 router script,info Max. route cache size: 65536
Dec 16 20:52:03 router script,info If active route cache size: 11731>=60000 reboot required
Dec 16 20:57:03 router script,info Actual route cache size: 11609
Dec 16 20:57:03 router script,info Max. route cache size: 65536
Dec 16 20:57:03 router script,info If active route cache size: 11609>=60000 reboot required
Dec 16 21:02:03 router script,info Actual route cache size: 11121
Dec 16 21:02:03 router script,info Max. route cache size: 65536
Dec 16 21:02:03 router script,info If active route cache size: 11121>=60000 reboot required
Dec 16 21:07:03 router script,info Actual route cache size: 10965
Dec 16 21:07:03 router script,info Max. route cache size: 65536
Dec 16 21:07:03 router script,info If active route cache size: 10965>=60000 reboot required
Dec 16 21:12:03 router script,info Actual route cache size: 10614
Dec 16 21:12:03 router script,info Max. route cache size: 65536
Dec 16 21:12:03 router script,info If active route cache size: 10614>=60000 reboot required
Dec 16 21:17:03 router script,info Actual route cache size: 11357
Dec 16 21:17:03 router script,info Max. route cache size: 65536
Dec 16 21:17:03 router script,info If active route cache size: 11357>=60000 reboot required
Dec 16 21:22:03 router script,info Actual route cache size: 10999
Dec 16 21:22:03 router script,info Max. route cache size: 65536
Dec 16 21:22:03 router script,info If active route cache size: 10999>=60000 reboot required
Dec 16 21:27:03 router script,info Actual route cache size: 10695
Dec 16 21:27:03 router script,info Max. route cache size: 65536
Dec 16 21:27:03 router script,info If active route cache size: 10695>=60000 reboot required
Dec 16 21:32:03 router script,info Actual route cache size: 10812
Dec 16 21:32:03 router script,info Max. route cache size: 65536
Dec 16 21:32:03 router script,info If active route cache size: 10812>=60000 reboot required
Regards,
