Hi there.
RB2011 here. Everything was wine for years until last month. Look at this:
To explain:
- 192.168.10.1 is RB2011 IP
- 192.168.10.113 is Windows 10 Pro Hyper-V Guest
So 192.168.10.113 is spamming router to the point, where CPU is on 100% (or vice versa?)constantly and cache entries are between 6000-10000, all looks the same as on screenshot. I can delete them manually but they are appearing almost every 30-40 seconds. Maybe the key is port number 2828? Like I said, never had this problem earlier, I think It happened after upgrading to 6.38.5 but I’m not 100% sure.
Can someone give any hint here?
UPDATE:
So, apparently, when you go to the link:
http://192.168.10.1:2828/gateway.xml
you’ll get some sort of XML file - something connected to UPNP service?
Bart
