Route display filtering
With OS7 bgp changes when you connect to a large ISP exchange peer you get a massive number of routes (in my case > 250K)
I know you can sort of filter down display using the “input Accept NLRI” but that doesn’t really help on a peer because you can’t really use a static address list on a dynamic peer. You also can’t use this for display only purpose not least of which because you have to restart the session for any change.
When the routes are displayed they show flags like DACSBbfI.
Really what I am wondering is if you can display routes based on those flags?
