Route error on public IP
I have a public class of IP’s 80.97.140.0/24 and the ether13 have the IP 86.127.70.132.
My computer who have manually set IP 80.97.140.99 shows me when I go to ripe.net that I have IP: 86.127.70.132 :open_mouth:
/ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 A S  0.0.0.0/0                          86.127.70.129      1
 1 ADC  80.97.140.0/24     80.97.140.1     bridge1            0
 2 ADC  86.127.70.128/26   86.127.70.132   13Internet         0
What could be wrong here?
You have a default route out ether13 and are masquerading outbound traffic on that port. Remove that NAT rule.
Post your NAT configuration if you need details (/ip firewall nat export).
Hello again fewi!
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add action=masquerade chain=srcnat comment="masquerade hotspot network" disabled=no src-address=10.5.50.0/24
add action=masquerade chain=srcnat comment="masquerade hotspot network" disabled=no src-address=80.97.140.0/24
I have tried yesterday to configure a hotspot and my be some nasty rules there. Today I did not make any tests (not enough time)
Later edit: I have removed rules 1 and 2 and now it’s working :wink:
Remove that last masquerade rule that lists your public IP space. It is unnecessary. The hotspot wizard doesn’t anticipate public IPs so it erroneously inserts that rule.
Done. Now it’s working. And you have +1 karma :wink: Tnx!
