I’m trying to setup router filters on V5.0 and V5.0rc10 with BGP and they aren’t working.
When I try to limit EVERYTHING, I’m still getting all the routes coming through.
What am I doing wrong?
Router 1:
add address-families=ip as-override=no default-originate=never disabled=yes
hold-time=3m in-filter=just_peers_in instance=default multihop=no name=Peer2
nexthop-choice=default out-filter=just_peers_out passive=no remote-address=
192.168.1.2 remote-as=2 remove-private-as=no route-reflect=no tcp-md5-key=
“” ttl=default use-bfd=no
Router 2:
Peer1 nexthop-choice=default out-filter=just_peers_out passive=no
remote-address=192.168.1.1 remote-as=1 remove-private-as=no
route-reflect=no tcp-md5-key=“” ttl=default use-bfd=no
Route filters are the same on both:
add action=reject chain=just_peers_in disabled=no invert-match=no prefix=0.0.0.0
add action=reject chain=just_peers_out disabled=no invert-match=no prefix=0.0.0.0
