Route Internet traffic MT via WireGuard tunnel through MT WG peer
Wanted to thank you for taking your time to reply.
Sure.
leave IP/DHCP Server DNS setting active but blank,
of course, that’s not gonna work. :smiley:
ALso added fasttrack
Good, check the “connection-mark” you have to use “no-mark”
add action=fasttrack-connection chain=forward comment=FastTrack connection-mark=no-mark connection-state=established,related hw-offload=yes
Still didn’t get to Wireguard configuration
change the subnet and you should be good to go.
You said it does work on your smartphone, which DNS server did you use in the WG client?
Wireguard WireHole script actually uses Unbound DNS. So, DNS is assigned in config, it filters everything.
But i have not added it in MT WireGuard settings, didn’t even see a field for it.
@emilk
maybe only through terminal?
Check it
ip firewall filter print from=[find comment=FastTrack]
Wireguard WireHole script actually uses Unbound DNS. So, DNS is assigned in the config, it filters everything.
But I have not added it in MT WireGuard settings, didn’t even see a field for it.
What I meant was what did you set as a DNS server in your laptop or smartphone Wireguad client? there is no DNS in MT for WG you have to use mangle and DST-NAT as I did in my config.
The local VDS DNS server.
Public DNS
None
[Interface]
PrivateKey = base64 key
Address = 10.0.6.3/32
DNS = 10.0.6.1
or
DNS = 1.1.1.1
or no DNS
[Peer]
PublicKey = base64 key
AllowedIPs = 0.0.0.0/0, ::/0
Endpoint = vpn.domain.com:port
