Hello All,
I am trying to leak a route from the main table to a vrf inside the same router.
So, basically I want a directly connected network of the router (in the main table) to be reachable from a specific VRF.
My current setup is with CCR1036 (6.32.2). I have been able to make this work only when the next-hop is not in the
router itself. As explained in the wiki http://wiki.mikrotik.com/wiki/Manual:Virtual_Routing_and_Forwarding
under “Static inter-VRF routes”.
Thanks in advance,
Ibra
