One problem really f***** up!!
After shutdown that happened because of electricity problems my rb2011uas-2hnd-in do not want to renew default routes.
Pppoe sessions starts and I can ping only providers servers
I need to disconnect each time and clear all the routes and then after connection Internet start to work properly
Please give me the cue
Save “/export compact”, netinstall and reimport the export (remember to save the export on the pc before netinstall…).
I need netinstall each time the problem appears?
Configuration is not deleted after shutdown
When I try to ping for example google.com I see
173.194.71.113 request timed out
But after deleting routes and reconnect everything works
But if routes can be deleted, they are not dynamic.
Why are they there in the first place?
Post your config for proper advice.
This is working routes
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 78.110.145.28 1
1 ADC 78.110.145.28/32 37.75.196.112 pppoe-out1 0
2 ADC 172.18.176.0/20 172.18.190.32 ether3 0
3 ADC 192.168.2.0/24 192.168.2.1 wlan2 0
4 ADC 192.168.88.0/24 192.168.88.1 bridge-local 0
This appears after wrong shutdown (electricity problems)
0 ADS 0.0.0.0/0 172.18.176.1 1
1 DS 0.0.0.0/0 78.110.145.25 1
2 ADC 78.110.145.25/32 176.62.254.7 pppoe-out1 0
3 ADC 172.18.176.0/20 172.18.190.32 ether3 0
4 ADC 192.168.2.0/24 192.168.2.1 wlan2 0
5 ADC 192.168.88.0/24 192.168.88.1 bridge-local 0
After pppoe reconnect first route is deleting and everything works with new adresses
i mean they are deleted after disconnect
I think one “/export compact” of your config can explain something…
[center@MikroTik] > /export compact
jun/04/2014 15:11:47 by RouterOS 6.13
software id = -
add admin-mac=::::: auto-mac=no l2mtu=1598 name=bridge-local
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether6 ] name=ether6-master-local
set [ find default-name=ether7 ] master-port=ether6-master-local name=ether7-slave-local
set [ find default-name=ether8 ] master-port=ether6-master-local name=ether8-slave-local
set [ find default-name=ether9 ] master-port=ether6-master-local name=ether9-slave-local
set [ find default-name=ether10 ] master-port=ether6-master-local name=ether10-slave-local
/ip neighbor discovery
set ether1-gateway discover=no
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=CenterYES_security supplicant-identity="" wpa2-pre-shared-key=P@ssw0rd!QAZxsw2
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=free_inet supplicant-identity="" wpa2-pre-shared-key=12345678
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-ht-above country=russia disabled=no distance=indoors l2mtu=2290 mode=ap-bridge periodic-calibration=enabled
security-profile=CenterYES_security ssid=CenterYes_ tx-power=15 tx-power-mode=all-rates-fixed wireless-protocol=802.11
add disabled=no l2mtu=2290 mac-address=4E:5E:0C:2C:01:C7 master-interface=wlan1 name=wlan2 security-profile=free_inet ssid=FreeYES wds-cost-range=0 wds-default-cost=0
/ip hotspot profile
add hotspot-address=192.168.2.1 login-by=http-chap,trial name=hsprof1 trial-uptime=0s/0s
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=1h2m mac-cookie-timeout=3d rate-limit=1m/1m shared-users=unlimited
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=3des
add name=dhcp_pool1 ranges=192.168.2.2-192.168.2.254
add name=hs-pool-15 ranges=10.5.50.2-10.5.50.254
add address-pool=default-dhcp disabled=no interface=bridge-local name=default
add address-pool=dhcp_pool1 disabled=no interface=wlan2 name=dhcp1
/ip hotspot
add address-pool=dhcp_pool1 disabled=no interface=wlan2 name=hotspot1 profile=hsprof1
/port
set 0 name=serial0
/interface pppoe-client
add ac-name="" add-default-route=yes allow=pap,chap default-route-distance=1 dial-on-demand=no disabled=no interface=ether3 keepalive-timeout=60 max-mru=1480 max-mtu=1480 mrru=
disabled name=pppoe-out1 password=******** profile=default service-name="" use-peer-dns=yes user=*********
add bridge=bridge-local interface=ether2
add bridge=bridge-local disabled=yes interface=ether3
add bridge=bridge-local interface=ether4
add bridge=bridge-local interface=ether5
add bridge=bridge-local interface=ether6-master-local
add bridge=bridge-local interface=sfp1
add bridge=bridge-local interface=wlan1
add address=192.168.88.1/24 comment="default configuration" interface=bridge-local network=192.168.88.0
add address=192.168.2.1/24 interface=wlan2 network=192.168.2.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no interface=ether3
add address=192.168.2.0/24 comment="hotspot network" dns-server=8.8.8.8 gateway=192.168.2.1
add address=192.168.88.0/24 comment="default configuration" dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.88.1 name=router
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add action=drop chain=input dst-port=53 protocol=tcp
add action=drop chain=input disabled=yes dst-port=53 protocol=udp
add chain=forward protocol=udp
add chain=input protocol=udp
add chain=output protocol=udp
add chain=input protocol=tcp
add chain=forward protocol=tcp
add chain=input protocol=igmp
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add chain=forward comment="default configuration" connection-state=established
add chain=forward comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=ether3
add action=drop chain=forward comment="default configuration" connection-state=invalid
add action=drop chain=input src-address=116.8.0.0/14
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes to-addresses=0.0.0.0
add action=masquerade chain=srcnat comment="default configuration" out-interface=pppoe-out1
add action=masquerade chain=srcnat comment="masquerade hotspot network" src-address=192.168.2.0/24 to-addresses=0.0.0.0
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
/ip hotspot user
add name=admin
/ip service
set telnet disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip upnp
set allow-disable-external-interface=no
/lcd interface
set sfp1 interface=sfp1
set ether1-gateway interface=ether1-gateway
set ether2 interface=ether2
set ether3 interface=ether3
set ether4 interface=ether4
set ether5 interface=ether5
set ether6-master-local interface=ether6-master-local
set ether7-slave-local interface=ether7-slave-local
set ether8-slave-local interface=ether8-slave-local
set ether9-slave-local interface=ether9-slave-local
set ether10-slave-local interface=ether10-slave-local
set wlan1 interface=wlan1
/lcd interface pages
set 0 interfaces=sfp1,ether1-gateway,ether2,ether3,ether4,ether5,ether6-master-local,ether7-slave-local,ether8-slave-local,ether9-slave-local,ether10-slave-local,wlan1
/system clock manual
set time-zone=+03:00
/system watchdog
set no-ping-delay=0ms watchdog-timer=no
/tool mac-server
add interface=ether2
add interface=ether3
add interface=ether4
add interface=ether5
add interface=ether6-master-local
add interface=ether7-slave-local
add interface=ether8-slave-local
add interface=ether9-slave-local
add interface=sfp1
add interface=wlan1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=sfp1
add interface=wlan1
I know: the export always reveal all…
You forget to not add default dhcp route on ether3…
For fix all, paste this on you terminal:
/ip dhcp-client set [/ip dhcp-client find where interface=ether3] add-default-route=no;
alternative version wich not remove default route, but increase route-distance:
/ip dhcp-client set [/ip dhcp-client find where interface=ether3] default-route-distance=2;
Thank you! Now i will wait for new electricity problems)
Simly detach power and re-attach…
