The problem is that I can not ping the Port 7 from the network. I’ll be able to access the router from both networks.
I lack something firewall setup, or something else?
I can ping and get access to SFP part.
As I see it, the router could just manage both my WANs, I will not double my download or upload speed. But just might forwarede my port from the WAN side to the LAN side.
This is possible when you setup a second routing table for your second WAN and
then define IP Route → Rules to send the traffic to the correct routing table.
This is not required, with route tables you can define a rule based on source address.
But tagging the traffic and selecting a nexthop in a filter rule is possible as well.
I have this Routes
[admin@MSBR-Core01] > ip route print
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 X S 0.0.0.0/0 10.145.3x.129 1
1 A S 0.0.0.0/0 87.116.3x.218 87.116.3x.217 1
2 ADC 10.145.3x.128/25 10.145.3x.147 ether7 0
3 ADC 87.116.3x.216/29 87.116.3x.218 sfp1 0
4 ADC 192.168.1.0/24 192.168.1.7 TDC 0
Don’t put 2 default routes in the same table and expect to use both.
Think about what you want with the second interface and use either IP->Routes->Rules and two different routing tables,
or match all your traffic on the second interface and use a set nexthop.
No, not with dst-address! That is not a matching criterion for the different paths.
Use source-address for the matching. Match on source address of one interface and contains the default route
for that interface, put the default route of the other one in the normal table.
My config is of course completely different from what you have, but I just have a second routing table with
a default route for the second path (which is a VPN in my case, but that doesn’t matter), and an IP rule which
matches on the source network for that VPN and sets the lookup to that second routing table.
You are right, this fragment is not actually from my config, I run BGP on the GRE tunnel and receive the
routes from that (and put them in the alternative table).
