Route question
I just added a small network and the upstream provider gave me a /27 and is using the first IP address as the gateway on his side. Normally I would get a /30 between the upstream and me, but in this case he opted to do this instead.
The way that I setup the routing did not seem to work.
I setup the WAN port as 10.10.10.2/30 with the gateway as 10.10.10.1 (using private numbers as example not the real public ones)
I then setup a network of 10.10.10.17/28 on Port 2
I cannot ping 10.10.10.17
Any suggestions? Thanks in advance.
Shane
Who is this Id**t?
It’s the best practice…
no comment…
You must put all on the same lan: ether1 and all other public IP user…
Your provider NOT have a route like “if you search 10.10.10.17 goto 10.10.10.2”, but only
“if you search 10.10.10.0/27 goto it by 10.10.10.1”
if you can not add route on your provider gateway, you must put all on the same LAN, without sub-net…
