Route Reflector
Hi, Can someone show me or give an example of how to make a reflector router using mk x86? Or would you rather have some video material on that subject?
Wiki has this article:
https://wiki.mikrotik.com/wiki/Manual:BGP_based_VPLS#Configuring_Route_Reflector
Hope I can help you!
the configuration luckily doesn’t depend on the platform, so it will be the same for x86 and other CPU types - but the convergence will definitely excel with x86.
do you plan to use MPLS? what address families do you want to “reflect”? IPv4, VPNv4 or L2VPN?
will your route reflector as as “control-plane only” or will it be a forwarding one?
