Route selection between 2 or more static routes
I have installed 2 static routes (non-BGP), because I have 2 uplink with 2 gateways (e.g. 10.0.1/24 & 10.0.2/24)
By default we all know only one static route could be active and could forward packets to next hop destination.
So how can I use both routes?
this is what I read on wiki page:
For non-BGP routes this can happen only if you are playing with filters. Scope attribute also determines which routes can be active.
Should I use scope attribute?How?
thanks
We need to know more information about this network to help you further.
  1. Are these networks to the world? (it sounds like they are)
  2. Do you run public or private addresses behind the router?
  3. If you run public addresses do you have addresses from each provider?
  4. Are these routes redundant to the same upstream provider?
    Ryan
    Ryan
