After upgrading from v2.x to V3.18 the mikrotik has issues with route selection, in that it is selecting a route with a higher administrative distance, ie below the first route is active, yet it has a higher AD, It does not switch instantly, you can disable the first static route and the second route will become active, then you can re-enable the first route and the second route will still remain the preference as it should, however if you leave it for 5-10 minutes the preference will switch back to the first route with the higher AD.
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
DST-ADDRESS PREF-SRC GATEWAY-STATE GATEWAY DISTANCE INTERFACE
1 A S 0.0.0.0/0 reachable 192.168.1.254 2 Trusted Wireless and LAN Bridge
2 DS 0.0.0.0/0 reachable 203.152.96.95 1 Wired Country PPPOE Internet connection
Any ideas? It is driving me crazy and makes no sence.
Cheers
Stephen
