Example:
I have two eBGP peers between one Mikrotik and one Cisco router over two different physical links.
Cisco router is originating default route on both peers and priority of the route on Mikrotik side is manipulated with “local preference”.
Also, there are two static default routes with “administrative distance” over 200 on Mikrotik side.
With both links active, routing looks good, active route is eBGP route with better “local preference” of 170 and AD of 20:
[admin@MikroTik] > ip route print detail
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
0 ADb dst-address=0.0.0.0/0 gateway=172.20.48.49 gateway-status=172.20.48.49 reachable via Vlan2992 distance=20 scope=40 target-scope=10 bgp-as-path="1212" bgp-local-pref=170 bgp-origin=igp received-from=Primary
1 S ;;; Primary static
dst-address=0.0.0.0/0 gateway=172.20.48.49 gateway-status=172.20.48.49 reachable via Vlan2992 check-gateway=ping distance=220 scope=30 target-scope=10
2 S ;;; Backup static
dst-address=0.0.0.0/0 gateway=172.20.48.125 gateway-status=172.20.48.125 reachable via Vlan2966 check-gateway=ping distance=230 scope=30 target-scope=10
3 Db dst-address=0.0.0.0/0 gateway=172.20.48.125 gateway-status=172.20.48.125 reachable via Vlan2966 distance=20 scope=40 target-scope=10 bgp-as-path="1212" bgp-local-pref=160 bgp-origin=igp received-from=Backup
4 ADC dst-address=172.20.48.48/30 pref-src=172.20.48.50 gateway=Vlan2992 gateway-status=Vlan2992 reachable distance=0 scope=10
5 ADC dst-address=172.20.48.124/30 pref-src=172.20.48.126 gateway=Vlan2966 gateway-status=Vlan2966 reachable distance=0 scope=10
6 ADC dst-address=172.20.249.13/32 pref-src=172.20.249.13 gateway=Loopback 0 gateway-status=Loopback 0 reachable distance=0 scope=10
After I disconnect primary link, default static route with worse AD (230) than the Backup BGP route (20) becomes the active route:
0 S ;;; Primary static
dst-address=0.0.0.0/0 gateway=172.20.48.49 gateway-status=172.20.48.49 unreachable check-gateway=ping distance=220 scope=30 target-scope=10
1 A S ;;; Backup static
2 Db dst-address=0.0.0.0/0 gateway=172.20.48.125 gateway-status=172.20.48.125 reachable via Vlan2966 distance=20 scope=40 target-scope=10 bgp-as-path="1212" bgp-local-pref=160 bgp-origin=igp received-from=Backup
3 ADC dst-address=172.20.48.48/30 pref-src=172.20.48.50 gateway=Vlan2992 gateway-status=Vlan2992 reachable distance=0 scope=10
4 ADC dst-address=172.20.48.124/30 pref-src=172.20.48.126 gateway=Vlan2966 gateway-status=Vlan2966 reachable distance=0 scope=10
5 ADC dst-address=172.20.249.13/32 pref-src=172.20.249.13 gateway=Loopback 0 gateway-status=Loopback 0 reachable distance=0 scope=10
MT configuration:
[admin@MikroTik] > export compact
# jan/02/1970 01:23:54 by RouterOS 6.44.5
# software id = HXN9-361D
# model = RouterBOARD 3011UiAS
add name=BD-PtP-Backup
add name=BD-PtP-Primary
add name="Loopback 0"
set [ find default-name=sfp1 ] comment=Backup-link name=Gi0/1
set [ find default-name=ether1 ] comment=Primarni-link name=Gi1/1
/interface vlan
add interface=BD-PtP-Backup name=Vlan2966 vlan-id=2966
add interface=BD-PtP-Primary name=Vlan2992 vlan-id=2992
/routing bgp instance
set default as=64532 redistribute-connected=yes redistribute-static=yes router-id=172.20.249.13
add bridge=BD-PtP-Backup hw=no interface=Gi0/1
add bridge=BD-PtP-Primary hw=no interface=Gi1/1
add address=172.20.48.50/30 interface=Vlan2992 network=172.20.48.48
add address=172.20.48.126/30 interface=Vlan2966 network=172.20.48.124
add address=172.20.249.13 interface="Loopback 0" network=172.20.249.13
add check-gateway=ping comment="Primary static" distance=220 gateway=172.20.48.49
add check-gateway=ping comment="Backup static" distance=230 gateway=172.20.48.125
/routing bgp peer
add hold-time=1m in-filter=BGP_UPSTREAM-1_ALL_IN keepalive-time=20s name=Primary out-filter=BGP_UPSTREAM-1_ALL_OUT remote-address=172.20.48.49 remote-as=1212 ttl=default
add hold-time=1m in-filter=BGP_UPSTREAM-2_ALL_IN keepalive-time=20s name=Backup out-filter=BGP_UPSTREAM-2_ALL_OUT remote-address=172.20.48.125 remote-as=1212 ttl=default
/routing filter
add chain=BGP_UPSTREAM-1_ALL_OUT set-bgp-communities=1212:10170
add chain=BGP_UPSTREAM-2_ALL_OUT set-bgp-communities=1212:10160
add chain=BGP_UPSTREAM-3_ALL_OUT set-bgp-communities=1212:10150
add chain=BGP_UPSTREAM-1_ALL_IN set-bgp-local-pref=170
add chain=BGP_UPSTREAM-2_ALL_IN set-bgp-local-pref=160
add chain=BGP_UPSTREAM-3_ALL_IN set-bgp-local-pref=150
Mikrotik wiki: “If a router learns about a destination from more than one routing protocol, administrative distance is compared and the preference is given to the routes with lower administrative distance.”
So the question is: What am I missing?
