route to CPE
not sure if been posted before, tried to search but couldn’t find any results.
would like add route to address on local LAN to my Mimosa dish, so i can access it.
local lan is on 192.168.0.XX and Mimosa is on 169.254.200.20.
mimosa is plugged into port 1(up link)
help would be appreciated
Add an IP address 169.254.0.1/16 to port 1 (or to the bridge of which it is a member) in parallel to the existing address, and add an action=masquerade rule to chain srcnat for dst-address=169.254.0.0/16. This should allow you to access the 169.254.200.20 from any device in your LAN, except if it itself has an address from 169.254.0.0/16.
ah, thank you.
will try that.
hi there.
finally had some time to actually sit down and set it up.
can access the Mimosa trough my phone, no problem
but trough my pc, i cant, keeps timing out, using CMD also says unreachable
