hope someone can enlighten me whats the cause of this error. I just notice this when i check the logs today.
pppoe,ppp error → route is not added bad prefix
here is the IP Routes and IP/FIREWALL MANGLE
IP ROUTES
Flags: D - DYNAMIC; X - DISABLED, I - INACTIVE, A - ACTIVE; c - CONNECT, s - STATIC; + - ECMP
Columns: DST-ADDRESS, GATEWAY, ROUTING-TABLE, DISTANCE
# DST-ADDRESS GATEWAY ROUTING-TABLE DISTANCE
;;; PBR ISP 1
0 Xs 0.0.0.0/0 192.168.1.1 to-ISP1-PLDT 1
;;; ISP PLDT (main)
1 Xs 0.0.0.0/0 192.168.1.1 main 2
;;; ISP3-CONVERGE(main)
2 Xs 0.0.0.0/0 192.168.100.1 main 1
;;; Main Route ISP1
3 As+ 0.0.0.0/0 8.8.4.4 main 1
;;; Main Route ISP2
4 s 0.0.0.0/0 8.8.8.8 main 2
;;; Check Gateway ISP1
5 As+ 0.0.0.0/0 208.67.222.222 main 1
;;; Check Gateway ISP2
6 s 0.0.0.0/0 208.67.220.220 main 2
;;; Recursive Check DNS ISP1
7 As 8.8.4.4/32 192.168.1.1 main 1
;;; Recursive Check DNS Isp 2
8 As 8.8.8.8/32 192.168.100.1 main 1
;;; More Detection ISP2
9 As 208.67.220.220/32 192.168.100.1 main 1
;;; More Detection ISP1
10 As 208.67.222.222/32 192.168.1.1 main 1
;;; BackUpRoute ISP1
11 As 0.0.0.0/0 8.8.8.8 to-ISP1-PLDT 2
;;; BackUpRoute ISP2
12 As 0.0.0.0/0 8.8.4.4 to-ISP3-Converge 2
FIREWALL MANGLE
Flags: X - disabled, I - invalid; D - dynamic
0 ;;; PBR to ISP1
chain=prerouting action=mark-routing new-routing-mark=to-ISP1-PLDT passthrough=no src-address-list=to-ISP1-PLDT dst-address-list=!PrivateIP in-interface=LAN-ETH5
log=no log-prefix=""
1 ;;; PBR to ISP2
chain=prerouting action=mark-routing new-routing-mark=to-ISP3-Converge passthrough=no src-address-list=to-ISP3-CONVERGE dst-address-list=!PrivateIP
in-interface=LAN-ETH5 log=no log-prefix=""
2 ;;; Web(Http + Https)
chain=prerouting action=mark-connection new-connection-mark=Web_Conn passthrough=yes protocol=tcp dst-port=80,443 log=no log-prefix=""
3 chain=prerouting action=mark-connection new-connection-mark=Web_Conn passthrough=yes protocol=udp dst-port=80,443 log=no log-prefix=""
4 chain=prerouting action=mark-packet new-packet-mark=Web_Up passthrough=no connection-mark=Web_Conn in-interface=LAN-ETH5 log=no log-prefix=""
5 chain=prerouting action=mark-packet new-packet-mark=Web_Up passthrough=no connection-mark=Web_Conn routing-mark=to-ISP2-Globe in-interface=bridge-LAN log=no
log-prefix=""
6 chain=prerouting action=mark-packet new-packet-mark=Web_Down passthrough=no connection-mark=Web_Conn in-interface-list=WAN-LIST log=no log-prefix=""
7 ;;; IPTV GLOBAL
chain=prerouting action=mark-connection new-connection-mark=IPTV_Con passthrough=yes protocol=udp dst-port=8554,9874,5001,5002,5003 log=no log-prefix=""
8 ;;; IPTV MARKPACKET
chain=prerouting action=mark-packet new-packet-mark=IPTV-PCKT passthrough=no protocol=udp connection-mark=IPTV_Con in-interface=LAN-ETH5 log=no log-prefix=""
9 chain=prerouting action=mark-packet new-packet-mark=IPTV-PCKT passthrough=no protocol=udp connection-mark=IPTV_Con in-interface=bridge-LAN log=no log-prefix=""
10 ;;; ICMP
chain=prerouting action=mark-connection new-connection-mark=ICMP_Conn passthrough=yes protocol=icmp log=no log-prefix=""
11 chain=prerouting action=mark-packet new-packet-mark=ICMP_Up passthrough=no connection-mark=ICMP_Conn in-interface=LAN-ETH5 log=no log-prefix=""
12 chain=prerouting action=mark-packet new-packet-mark=ICMP_Up passthrough=no connection-mark=ICMP_Conn in-interface=bridge-LAN log=no log-prefix=""
13 chain=prerouting action=mark-connection new-connection-mark=ICMP_Down passthrough=no connection-mark=ICMP_Conn in-interface-list=WAN-LIST log=no log-prefix=""
14 ;;; DNS
chain=prerouting action=mark-connection new-connection-mark=DNS_Conn passthrough=yes protocol=tcp dst-port=53 log=no log-prefix=""
15 chain=prerouting action=mark-connection new-connection-mark=DNS_Conn passthrough=yes protocol=udp dst-port=53 log=no log-prefix=""
16 chain=prerouting action=mark-packet new-packet-mark=DNS_Up passthrough=no connection-mark=DNS_Conn in-interface=bridge-LAN log=no log-prefix=""
17 chain=prerouting action=mark-packet new-packet-mark=DNS_Up passthrough=no connection-mark=DNS_Conn in-interface=LAN-ETH5 log=no log-prefix=""
18 chain=prerouting action=mark-packet new-packet-mark=DNS_Down passthrough=no connection-mark=DNS_Conn in-interface-list=WAN-LIST log=no log-prefix=""
19 ;;; VOIP / ZOOM
chain=forward action=mark-packet new-packet-mark=voip passthrough=yes protocol=udp packet-mark=voip dst-port=3478-3481 log=no log-prefix=""
20 X ;;; CONVERGE
chain=prerouting action=mark-routing new-routing-mark=to-ISP3-Converge passthrough=no src-address-list=to-ISP3-CONVERGE log=no log-prefix=""
21 ;;; No Balance Traffic entry on PPPoE
chain=prerouting action=accept src-address-list=PPPoE_List dst-address-list=PPPoE_List log=no log-prefix=""
22 ;;; Access to ISP Routers
chain=prerouting action=accept dst-address-list=WAN_LIST log=no log-prefix=""
23 ;;; Input
chain=input action=mark-connection new-connection-mark=ISP1_Conn passthrough=yes in-interface=ISP1-PLDT log=no log-prefix=""
24 chain=input action=mark-connection new-connection-mark=ISP2_Conn passthrough=yes in-interface=ISP3-ETH7 log=no log-prefix=""
25 ;;; Connection Mark to ISP
chain=prerouting action=mark-connection new-connection-mark=ISP1_Conn passthrough=yes connection-mark=no-mark in-interface=ISP1-PLDT log=no log-prefix=""
26 chain=prerouting action=mark-connection new-connection-mark=ISP2_Conn passthrough=yes connection-mark=no-mark in-interface=ISP3-ETH7 log=no log-prefix=""
27 ;;; Output
chain=output action=mark-routing new-routing-mark=to-ISP1-PLDT passthrough=no connection-mark=ISP1_Conn log=no log-prefix=""
28 chain=output action=mark-routing new-routing-mark=to-ISP3-Converge passthrough=no connection-mark=ISP2_Conn log=no log-prefix=""
29 ;;; PCC
chain=prerouting action=mark-connection new-connection-mark=ISP1_Conn passthrough=yes dst-address-type=!local connection-mark=no-mark in-interface=LAN-ETH5
per-connection-classifier=both-addresses-and-ports:2/0 log=no log-prefix=""
30 chain=prerouting action=mark-connection new-connection-mark=ISP2_Conn passthrough=yes dst-address-type=!local connection-mark=no-mark in-interface=LAN-ETH5
per-connection-classifier=both-addresses-and-ports:2/1 log=no log-prefix=""
31 ;;; Routing Mark
chain=prerouting action=mark-routing new-routing-mark=to-ISP1-PLDT passthrough=no connection-mark=ISP1_Conn in-interface=LAN-ETH5 log=no log-prefix=""
32 chain=prerouting action=mark-routing new-routing-mark=to-ISP3-Converge passthrough=no connection-mark=ISP2_Conn in-interface=LAN-ETH5 log=no log-prefix=""
This text will be hidden
